VMC3030 Wont Sync To Base Station
When trying to sync the VMC3030 camera to add on to my system the blue light does not blink when I depress the sync button.
When I inserted the batteries and closed the cover the light the blue came on momentarily. So I know there's contact.
The base blinks waiting for contact but camera won't blink. The other cameras I have blink. I'm beginning to think the camera's defective. The batteries check good.
What's going on?????????????
Try the batteries from a camera that works so you absolutely know it's not the batteries. Failing that, it probably is a fault with the camera. Make sure you only briefly depress the sync button on the camera to get the blue light flashing slowly, if it works
