  • 6 Replies
  • 4203 Views
joepg
motion detection has been working I turned the cameras off for a time and now the motion detection will not stay on. I've readjusted sensitivity but will not stay on. The icon turns off when I go live.
6 REPLIES 6
It is working normally.... When you go LIVE, your over-riding the motion detect and it turns off ( you can manually start a record if need be ).
  When you exit LIVE the motion detect will automatically come back on if it was set prior.
Is it possible the batteries are weak?
joepg
no the batteries are just fine. This unit is 5 days old. I wish you people would stop replying with stupid questions.
The question wasn't stupid at all... it is a common problem we see that many users don't think of.
BTW, not the way to get help
joepg
there you go bad rap the customer. I fixed it myself.
I don't work for Netgear, just a user too
