VMC3030 4th camera does not sync properly
I have successfully connect three of the cameras. The fourth camera will not sync properly. When I do the sync the camera number appears in Settings/My devices but when I try to access that camera in Live View I always get the message that "The request has timed out". This is very frustrating, please advise.
try and go to settings> camera and REMOVE the DEVICE ( camera ) completely, then bring it back as if new
Thanks, Tom. I had tried that previously but tried again to no avail. I went to Best Buy and bought a single camera and it synchronized fine. I tried the problem camera and it still does not sync. After multiple tries it has appeared in Settings/MyDevices but when I try to access it I still get the message "Your request has timed out". How do I get hold of Net Gear Customer service to get credit for this faulty camera. I have four cameras working on the system but want five total.. Thanks, Mike
Top of page Support
next page on upper right Contact Support
mike232,
This does sound like it could be an issue with the camera. One last thing you could try, just to further isolate, is a fresh set of batteries in the affected camera (you could temporarily use the batteries from your working add-on camera to test).
Otherwise, if you're still experiencing an issue, I agree with TomMac's post above and advise contacting support for further investigation: Arlo Support Team
Mike242
