VMB5000r6 Stopped loading video to phone .
In library mode, the stored video doesn't load to view on my android cell phoen. Problem started approximately 2 weeks ago but I've had this set-up for several years with no problems loading stored video to phone. I also use a Galaxie Android to view stored video. It seems to working ok. I have deleted app from my phone twice and re-instllled to see if that would work but so far no luck.
Are you using app version 5.4.2?
I was not until this morning. After reading your post I checked my version and found a update. I updated but with no joy. Still same problem.
I feel sort of stupid right now. Got to digging around and comparing settings between phone and pad. Realized I turned off wi-fi on phone the other day. Turned it back on and everything is working fine. Didn't realze wi-fi had to be on.
