I have been using 3 Arlo Pro 2 cameras with a VMB3500 base station. I now want to add a video doorbell and couple of additional cameras. It appears that the VMB3500 base station will not support the video doorbell, and has a limit on the number of cameras. Is this correct? Does Arlo support trade-ins if someone wants to upgrade?
@GK1025 wrote:
Thanks @StephenB , this is very helpful. So if I understand correctly, additional doorbells and cameras can be purchased a la carte and connected directly to the home wifi network without having to invest in another base station, and I can still continue to use the old cameras as before.
Yes.
The cloud subscription requirement is certainly an inhibitor though. I suppose that does not include alert response either (notifying authorities in the event of suspicious activity etc.)
Emergency response is a subscription feature (Arlo Secure Plus), and is only available in the US. Note it isn't automatic, you would still need to initiate the response from the app.
With no subscription, you will get motion alert notification on your phone, and can view live video (but no recordings). Contacting authorities would be up to you, and would not be done from the app.
It definitely doesn't support the video doorbell or any of the newer cameras. Not sure if there is a strict limit on cameras (this isn't a base I use).
No, though personally I think it would be a good idea for them to do that.
Many newer cameras (Pro 3 floodlight, Pro 4, Essential, and the doorbells) can connect directly to your home wifi with no base station.
Also, hopefully you are aware that all of the newer cameras (starting with the Ultra back in 2018) will require a subscription for cloud storage. Arlo stopped offering the free 7-day cloud storage (though you still have it with older cameras like the Pro 2).
The Arlo web site is very confusing, and I couldn't even find a customer support contact number to call for questions.
Yes.
						Accessories4
						Activity Zones1
						Amazon Alexa1
						Apple HomeKit2
						Apple TV App9
						Applications mobile et en ligne1
						Apps4
						Arlo Go3
						Arlo Mobile App722
						Arlo Pro36
						Arlo Pro 21
						Arlo Q (Plus)3
						Arlo Smart196
						Arlo Web and Mobile Apps18
						Arlo Wire-Free30
						base station1
						Batteries529
						Before You Buy925
						Can't view cameras live at all1
						Dépannage1
						Détection de mouvements1
						Features1,070
						Fehlerbehebung1
						Firmware Release Notes93
						Google Assistant1
						Hardware1
						home security1
						IFTTT (If This Then That)105
						Installation2,046
						Iphone 14 pro1
						Live view1
						Modes and Rules1
						Motion Detection2
						Object Recognition3
						Online and Mobile Apps983
						Online und mobile Apps1
						Order Not Going Through... help please!1
						Other Discussions1
						Partner Integrations4
						Security1
						Service and Storage14
						Smart Subscription3
						SmartThings71
						Troubleshooting9,083
						Videos233
						Vidéo2
						Warranty & Contracts2
