VMB3000 keeps turning on and off and wont connect to cameras after I changed the batteries
My base station keeps turning on and off and is not staying on consistanly. We rest the system and it did nothing.
Also we have tried to reinstall the entire system and now it only works with one camera. We keep trying to sync other cameras and it wont work at all. Both the cameras and the base station blinks but they dont connect.
You did a full system reset? Remove all devices from your app. Hold the reset button down on the base station til the lights blink. Wait for it to re-power up. Login and claim the base station. Then hit the sync button on the base and sync the cameras. If this doesn't work, contact support at the bottom of the page
