VMB3000 External HD
Hi All,
I'll just cut to the chase... Can I use the following External Hard Drive with my Arlo?
https://www.amazon.co.uk/Seagate-FreeAgent-500GB-Portable-Drive/dp/B001EASPZW
Andy
No. This is the original wireless base and, although it has 2 USB connectors, they're not field-usable for anything. You would need to buy a Pro base to be able to use a USB device attached to the base. All wireless cameras work with any wireless base.
Seems pointless having USB ports there doesnt it?
jguerdat wrote:No. This is the original wireless base and, although it has 2 USB connectors, they're not field-usable for anything. You would need to buy a Pro base to be able to use a USB device attached to the base. All wireless cameras work with any wireless base.
