VMB3000 Arlo Wireless Camera Amber LED
  • 1 Reply
  • 3000 Views
03DJC
I have connected one camera but the other 3 will not connect. A amber light comes on and off when I try to sync and not the blue light as the first one did correctly.  What do you suggest?
steve_t
Master Master
Amber light means the camera batteries are flat. Replace them with new CR123A batteries and you should be able to sync
