  • 9 Replies
  • 2156 Views
wayspang
VBM3000 is setup and active but doesn't show in device list. Firmware won't update but can't do it manually since it doesn't show in devices. Reset unit twice but same result.
9 REPLIES 9
Dannybear
Are you logging in to the master account or a friend account? Friend accounts will not show the base stations.
wayspang
I created a new account. Not aware of master or friend status.
Dannybear
Can I assume that this is a first time setup. That model base is old so is it 2nd hand, refurbished?
When it asks to update firmware when you try adding the Base if you continue without updating does it then show up under the settings/My Devices list?
wayspang
Yes this is first time setup and it is 2nd hand. When I continue it says it can't update but then says it is active but does not show up in the device list.
ShayneS
Are you still experiencing this issue?
wayspang
Yes I am. Thank you!
ShayneS
Does the web portal show the same as the Arlo app? Have you tried installing the base station via the web portal as well?
wayspang
Yes I tried the web portal and the app. Same result
ShayneS
Do you have a screenshot of the missing base station in the device list? Have you tried syncing a camera to the base station?
