Using mount which places camera upside down? Cannot flip image?
Using the mount which places the camera upside down. I tried to flip the image but when I look in video settings, the only option is to change the brightness. There used to be a way to do it but not any more. Any help would be appreciated!
Under video settings I still have "rotate image 180" in both web and IOS app. Not sure if you are in video setting then lowlight settings where brightness is.
