I pressed the triangular sync button on the side of the base station for too long, and the USB light began to flash. I pressed the same button again, and the box said "three". I pressed again and it said "2", and a third time it said "1". I am unable to sync any of my three cameras at present, and all were working before. One stopped working (said ift was offline), so I tried to sync which started this incredible mess. Any ideas?
Ed
Power cycle the base. If that doesn't work, you may need to reset the base holding the reset button until the LEDs flash amber. Remove all devices in Settings, My Devices. Use the Add Device button in the Cameras tab to add the base and sync the cameras. Be sure to press the base sync button only briefly, <1 second.
As a PS, holding the sync button puts the base into an unknown USB mode...which has been reserved for future options
