Unpairing Arlo base station from Apple Home
  • 1 Reply
  • 236 Views
donelbo2
I moved houses, deleted my Apple Home, and created a new one.
I should have unpaired the base station from the old home before deleting it.
I can't add the bridge to the new home because it says it's already paired to the old home.
Any ideas on unpairing the base station?
ShayneS
@donelbo2
If you're using the same network/password you should be able to plug it in and everything will work. Can you provide more detail on what you are trying to achieve?
