Unable to detect any arlo device
  • 6 Replies
  • 5259 Views
  • 2 Likes
KimberlyJoy
I just purchased the ARLO 3 wire free HD Security camera kit. Model No. VMS3330W. Followed instructions on setting up the base, syncing a camera and downloading app. When trying to add device, it tells me my base station could not be discovered. HELP!!
KimberlyJoy
GREAT NEWS!!  My system is working. Thank you, all of you, for your assistance. Reseting the base and starting over fixed the issue. I'm thinking I plugged in before plugging into the app. Thanks again!
6 REPLIES 6
Streak2
Master Master
Make sure that your device on which the app is installed is on the same network as the base. ie. if the base is plugged into your home router then make sure that your app device is also on the same wifi network and not using cellular data.
Alos, make sure you claim the base before syncing the cameras/
KimberlyJoy
Both my phone and my laptop that I am using are utalizing my home wifi network. Still not working.
KimberlyJoy
I only have one camera synced to the base station. Should I do a factury reset and start over?
Streak2
Master Master
Do you have both green lights illuminated on the base?
Have you followed these instructions:-
https://kb.arlo.com/1179139/How-do-I-connect-my-Arlo-or-Arlo-Pro-base-station-to-the-Internet
If so, then yes, reset the base
https://kb.arlo.com/1057976/How-can-I-reset-my-Arlo-base-station-to-the-default-values
KimberlyJoy
