Ultra 2 or pro 5s 2K
I have been deciding which cameras to get. Apart from the additional motion sensor and 4k in ultra 2, is there any other difference ? Does ultra 2 have dual band WiFi ? The prices are similar in both while the ultra 2 is a little more expensive Pro 5s seems to be a newer product, is there any advantages over ultra 2? Thankyou !
Yes.
The Pro 5s can connect either to a smarthub or to your home wifi, the Ultra can only connect to a smarthub.
The Ultra does have a somewhat wider field of view (180 degrees diagonal, compared with 160 degrees). It also has wind reduction (which the Pro 5s lacks).
Personally I wouldn't count the additional motion sensor as a feature. I think it is there simply because this particular camera needed two sensors to cover the field of view.
