Ultra 2 keeps recording 10s clips locally
I set up my Arlo 2 this weekend. I have set activity zone, and reduced audio sensitivity to minimum. I’m getting many 10s clips recorded on the local SD card, with no notification, and without them showing up in the Cloud tab. Only in the Local tab. The clips list Motion as the reason, but nothing at all moves in the clips. I find it strange that if motion is detected there is not also a Cloud clip and notification. What to do?
Thanks for the feedback. Can you provide more details regarding the symptom you are experiencing?
