I am not able to give access to my cameras to any other user. I have followed all instructions and possible tips from the community, and at the moment it looks like it is due to different UIs:
My iPhone (IOS 16.3.1) has app version 4.2 (5730), and since I have a Pro 5 camera, the UI is new, e.g. using "feed" instead of "library".
When I install the same app version on a friend's iPhone, the UI is old.
If I log in with my credentials on her phone the UI changes to the new. But when I log in with her credentials again, the UI reverts back to the old and no cameras.
How do I fix this?
Are you following the process that clicking on the invitation's embedded link provides? If so, a new user that never had an account should automatically get the new UI so it sounds like she has had a previous account. Regardless, you can force her account to the new UI by choosing to install a Pro5 or security system in her login. You don't have to have either, you're just causing the migration to occur. After the account migrates as a first step, simply cancle/back out of the fictitious install.
Great, that was it. Thank you
