Timed disarm
  • 1 Reply
  • 1869 Views
dash5375
I was hoping there is a way to due set a timed disarm. After the timer elapses the system reactivates to the mode that was active when the timed disarm was set. That way, I don't forget to rearm. If not available, this would be a great enhancement.
You can set a timed mute for notifications, which is a similar concept.  You still get recordings (and there are only a few settings for the timer).
