Temperature
The instructions say these cameras operate to -10° C but I had anyone tried it in colder climates? I’m wanting to use them in Calgary.
The original Arlo HD cameras ( that use 4 - 123 cells ) I have have just below -10 F and they were still working with a slight sag of the battery voltage ... How much lower it would go is unknown. As temps get really cold there is a slow down on the chemistry to make the battery work as normal as it can put out less.
The Pro/Pro2 I have tested both and they both shut down at about -4F ( built into camera )
