That would be a nice feature. If this happens again, I believe you can reset the base remotely which should resync the cameras.
Brian
Resetting the base station can be done and is sometimes the reason the cameras go offline believe it or not. Sometimes it will randomly drop one off the cameras. Reboot it enough times and you can sort of cycle through them which helps a little off it is cameras that are mounted high, but again it will require someone to be on site to re-sync any that don't come back online.
ryanofford,
The cameras do automatically attempt to resync when they lose connection with the base station. If they remain offline as you describe, this could be due to poor signal strength or interference that is causing the cameras to struggle maintaining their connection to begin with.
How far from the base station are the cameras that have this issue? What does your signal strength indicator show for those cameras?
ryanofford,
Try swapping the nearest cameras location with one of your other cameras and see if you still experience the same behavior. This will help isolate if the issue is occurring more due to camera location.
