Stuttering arlo recording
  • 7 Replies
  • 2542 Views
JonGriff
2 of these cameras plus a pro on my setup. One of the cameras records motion with a stuttering effect, almost like buffering. Upload speed is 10mb+ and the other camera (which is further away from base station) records without same issue. Any ideas ? Video example should attach here
7 REPLIES 7
Post a link to the video - you can't post it direectly.
Swap cameras around to see if it's the camera or location.
JonGriff
https://arlo.netgear.com/hmsweb/users/library/share/link/8A0A118177DE2956_201903
Sorry, should of said, I’ve tried it elsewhere and it does the same
Not sure what  would cause that. If network/signal related, I'd expect pixelation, too. If bothersome, try removing and resyncing the camera and ensure all firmware is up to date.  Otherwise, open a case with support:
JonGriff
Hi. @jguerdat Small update here. Camera moved (now closer to router) and still same problem. Went through the full batteries out / delete device / setup process.
Stuttering remains same:
https://arlo.netgear.com/hmsweb/users/library/share/link/2AE3116583B1F3B3_201903
You can try removing and resyncing the camera, otherwise open a case with support:
JonGriff
Contact is proving impossible on that link. Live chat NEVER connects and the email form says “something went wrong please contact support” (the irony!) when I press submit
Why not use the phone contact?
