  • 2 Replies
  • 1243 Views
Nivek911
The Arlo android app has no mode function visible. I have rebooted the phone. Reinstalled the app. I can only access mode via a PC.
MartinSwede
Hi.
Also noticed that issue since some time. But for me it works for some time but after a while mode is blank. If I shut all apps and sessions down so memory are deleted and then open up the app again it works but only for some time then mode is gone again. Believe an old problem which unfortunately have come back after latest update of Arlo. Really hope Arlo team fix the bug ASAP. Have 5 Arlo 2 Cameras and use Samsung S9 .
ShayneS
What version of the Arlo app are you using when you experience this issue?
What Phone/Device/OS are you running?
