Standard wireless Arlo camera
One of my cameras is displaying the picture in red almost like night vision the green grass is white & the general screen is red , any ideas please ??
Sounds like the IR filter stuck... Arlo HD camera ( see faqs re red picture )
Pull battery to reset and test... if less than a yr old contact Arlo re possible warranty
Arlo pro not responding to motion , works ok on live feed , but not activating with motion ... any ideas please ??
Arm the cameras, then verify in Live view screen the motion detect icon ( running man or ball with lines ) is Black.
Test
If still NG, then go to MODES and edit the mode you are using , Increase the sense level to trigger a recording
