After tapping "add new device" and "doorbells and chimes" none of the selections are active. I've tried 2 different iPhones and an Apple tablet. The apps are running the latest firmware. Is there a setting that I am missing on my Apple products?
Mike
Arlo app有一些制沒有反應
例如加新攝影機沒有反應 但其他3種都有反應下一步選型號. 重新啟動制亦冇反應 是完全按不到
Have you tired to uninstall and reinstall the Arlo App?
Yes, I also tried to install on the iPad and still same problem. Thank you.
hi
i am having trouble with selecting the camera on Arlo app.
Camera Button is non clickable on Arlo App
What do you mean by "none of the selections are active"? You may be in a country where they aren't supported yet.
https://kb.arlo.com/000062249/Where-is-Arlo-Secure-available
I'm located in Canada and have a coupe of cameras that work fine.
I mean when I tap them, nothing happens. None of the "doorbells and Chimes" selections are available which makes me think that I have a setting in my devices that needs to be changed but am unable to figure out which one.
And the question about what you mean?
While it's a long shot, try rebooting your phone and reinstall the app.
No change unfortunately.
Now the app is just completed broken. Can't add anything. Here is the link to the video. https://www.youtube.com/shorts/5zVuN3AB2Uo
I have the same problem with my Arlo app, exactly the same symptoms you describe.
Me neither ! I can select any product to add to my home base excepted camera
I added a camera to one of my VMB4000 units via the Arlo IOS app. I tried to share the camera to others. It was then that I noticed (using the IOS app) under the Account section it says "Getting Information" and it never changes/updates. Logging into to my.arlo.com, under Settings, "Device Settings", "Account" and "System" are greyed out and as such, I can't share the camera.
Is anyone else having this issue? If it's just me, any way of fixing this?
Note: I do not have a subscription plan, but just utilizing the 7 days of recording that comes with the legacy VMB4000 systems.
Are you still seeing this same behavior? Have you tried uninstalling and reinstalling the app?
Thank you for bringing this to our attention. I have passed this onto our development team. I will update the community as soon as possible.
Can you please log out of the app and log back in and see if it is resolved?
Hi,
I did this before my original posting. On the PC, using CClearner, I also cleared out the browser cache and DNS cache. I tried both Chrome and Firefox. On the iPhone, I went so far as uninstalling the app, re-installing the app and re-entering my login credentials. The settings didn't change.
If you mean log out and back in now, I didn't get a chance to update this posting yesterday, but I tried again last night because I saw somewhere Arlo was migrating back end systems (?) I don't know if that is true and/or even related, but the "Grant Access" option now appears again on both the PC and the IOS app. No idea why, but just happy it's back.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
