Solution to Pink Screen problem
I am posting here because a previous topic on this was closed. Knocking the camera a bunch of times (suggested on the previous post) with my hand worked! If it doesn't work the first time try a few more times. Also, try with both batteries in and out.
Hope this helps someone.
Known issue due to IR filter sticking in place.
