This is regarding the Android app. Since the last updatae which is dated 5/26/18 Geofencing is not working correctly. Geofencing set on 2 phones and when both Out of Zone one phone is showing as In Zone all the time even though the map shows it located Out of Zone. Also setting the schedule is a pain. Unable to set system to be armed from 8pm until 7am unless 2 schedules are set up, 8pm-12am and 12am-7am. Also setting a schedule to arm starting at 8pm until 12:00am I get an error saying the stop time should be after the start. This is on the phone but not on the PC browser. Also when I set the two schedules using the PC browser for 12:00am to 7:00am for all 7 days, when reviewing the schedule on the phone it shows the armed time to only occur on Monday. This has been a pain and keeps the system from working as I want. I do not feel my home is secured against instrusion. What is going on and when do you expect to fix these issues?
Hi @Rellis
Have you made sure your base station is up to date on the latest firmware? I have attached the firmware notes here - Firmware Release Notes
Also, can you update to the latest Arlo Mobile App 2.7.6 & test again.
Due to the amount of issues described I have opened a case for you. I will contact you via private message with further information.
Thanks very much for escalating this but it is crazy it would take 10 months from the first report that Geofencing was NOT working to finally do this. And why isn't the VMB4000 model listed to be selected? I would have selected a model but none available match any of the devices on my system.
Has anyone experienced this?
I even set the geofencing settings backwards, armed when home and disarmed when away, and it still won’t work.
Very frustrating!
Please open a ticket and escalate for me
Hi @Jensplodgy
What troubleshooting steps have you previously performed? I do not want to suggest anything you may have previously performed.
I am not sure what troubleshooting you are expecting. I have enabled Geofencing, my GPS on Android is operating. The system notifies me that I have left Geofence zone and when I arrive back in Geofence zone. So all seems to be operating normally except that the cameras did not provide any motion detection - even though there were several deliveries to my house at this time.
I may be a little naive, but I am expecting Geofence to just operate? However, I am happy to run through any steps you feel I should undertake.
In the meantime, when I want the system to operate i.e. when I leave the property or overnight I am using manual modes to ensure all is set.
You can try to reboot the base station & test again for positive results. If motion is still not being recorded by events, you can reboot the cameras by opening close ing the battery door. If this does not help, you can remove the cameras from Settings > My Devices > Re-Add them.
So for a few weeks now (since the base station firmware update for sure) schedules don't work when switching modes- or geofencing for that matter.
Modes don't switch when you enter or leave geofencing zones, I know that. But the "fix" was to manually set a different mode, then set it to geofencing again. Except that didn't work for a schedule.
We have 2 base stations at two homes. On our residence the schedule turns all cameras on at midnight when we are in zone, and at 8 am the inside ones are disarmed. The only way to actually have that happen is to set the mode to Schedule. If it is in Geofencing mode AND it recognizes we are in zone it disarms all.
I have deleted my schedule and rebuilt it (on a browser, not with the app). No change.
I am currently sitting in our residence. The app is showing that both my wife and I are in zone. Instead of being in the "Home, daytime schedule" the system is disarmed. Our vacation home is set to geofencing, the app shows we are both out of zone (because we're not there) but the mode is currently disarmed. I just changed modes to Armed. Looked at Devices, cameras are armed. Set it back to Geofencing, got an alert saying "Arlo Geofencing at XXXX is now Away mode". Terrific, except when I look at the actual mode displayed it is Disarmed and the Devices are showing as disarmed. Well, the ones that are working, one camera is showing as offline on the app, but if I look using a browser it is connected no problem.
So how many broken things are detailed in this post? I can't even count them all...
