This is regarding the Android app. Since the last updatae which is dated 5/26/18 Geofencing is not working correctly. Geofencing set on 2 phones and when both Out of Zone one phone is showing as In Zone all the time even though the map shows it located Out of Zone. Also setting the schedule is a pain. Unable to set system to be armed from 8pm until 7am unless 2 schedules are set up, 8pm-12am and 12am-7am. Also setting a schedule to arm starting at 8pm until 12:00am I get an error saying the stop time should be after the start. This is on the phone but not on the PC browser. Also when I set the two schedules using the PC browser for 12:00am to 7:00am for all 7 days, when reviewing the schedule on the phone it shows the armed time to only occur on Monday. This has been a pain and keeps the system from working as I want. I do not feel my home is secured against instrusion. What is going on and when do you expect to fix these issues?
Just purchased a set of three cams with a base (Arlo Pro) from Costco. THIS is the exact problem I am having! So frustrating. Is it time to return and leave a bad review or is Arlo doing something about it?
The schedule works fine, but I don't want to leave my house unmonitored when I leave during the day. Leaving it on is fine, but then I have literally dozens of alerts as my kids come home from school or I pull out my garbage cans.
I NEED the geofencing plus schedule to work!
I have tried a ton of stuff, including the following:
- Multiple resets of the base and the cams.
- Remvoing the app and data from my phone.
- Reducing the number of phones that are geofencing down to just one.
- Changing which phone is geofencing.
- Setting it up from the app and/or the PC
- Factory resetting and trying the whole thing again.
I literally told my Mom to buy this system too. Are we both returning it? How can this "feature" be unusable for so many people for so long. Any help?
Jakelly, with the last update it appears that Geofencing is finally working. There are a few things you need to keep in mind when you are using this feature. For instance you need to make sure that Arlo is allowed to see the GPS and the biggest thing is that Arlo needs to be active in the device, which is the same as running in the background, while you have the app set to Geofencing. The reason for this is Arlo needs to see the status of the GPS and it will not see anything if the app is not running. I always check Arlo when I leave to make sure the required switch occurs. If it hasn't then if you set the Mode to armed if leaving and disarmed if returning then back to Geofencing that should get it to set correctly. This can be a pain at times, but necessary if you want the system to work the way you want. Hope this helps.
OurHattonHome, what's the point of Geofencing, if you have to keep on adjusting it when you're in the zone and away. Might as well remove it and just set it manually everytime. It used to work ok before, it detects when you're away or in the zone and changes the mode according to your setting but it hasn't work right in the last 3 months. I just set mine to scheduled and that is kind of ok because I know approximately when there's gonna be someone at the house and I just use it to do manual live view to check.
Matchpoint, You are correct. Having to manipulate Geofencing at anytime after it is selected is not ideal. I was only trying to answer the question as to why it would not be working and what to do to get it to work. I've always had an issue with Geofencing working if the app was not running the in background. If you only have had an issue with it for a few months count yourself lucky. I just wish it was working correctly so once set I would not have to fool with it ever. But it has been over 6 months since the issue was reported with nothing has been done about it. Just wish they would fix it so I can use it. And I have to stand corrected. Geofencing is NOT working correctly anymore. I tested it the other night when it showed as being armed as set in the app but nothing was being picked up and the lights on the camera would not come on as they are supposed to when armed. I wish they would just get rid of Geofencing since they are unable to make it work right.
New Arlo user and this is happening here too...on a Geofenced schedule and everything is disarming (all six cameras) at 12 midnight when it should be armed.
Iin away mode it is set to armed
In home mode it is set to schedule
When home the schedule doesn’t seem to always work and the system states it is disarmed albeit according to the schedule it should be armed.
Can anyone help, thanks
Use a browser when checking/setting modes, rules and schedule. It works 100% of the time while the apps have display problems making you think one thing while another is actually true.
Hi
1. Browser is blocking me with Geofencing setup as it is only available in the Mobile App.
2. I do not care what realy web browser or app is showing as a status when in the moment when Im at home with both phones in the zone I do get all notifications when those should be off, just recording. Based on cameras behaviour, recording and notifications I see does it switch to the right mode or not.
But I will try this later today over next few days, maybe some updates in soft took place.
regards!
ShayneS from has responded to my post with some initial follow up questions, but nothing since then (early Nov).
It's been a couple of months since my original post, pretty frustrating!
I have geofencing mode whichbis switchibg between Armed and my Custom mode. I setngeofencing range to medium (i reccomend to try large). Small radius is not allowing the system to switch fast and Im at home and software still works in the previous mode causing strange behaviour. Give the system more time so go to medium or large radius for geofencing and you will switch modes before entering the house doors. I also have mode switch notifications so I know when the mode switch takes place. Is shifts to Armed Mode when Im leaving house in the same place very quickly. But for sure I see that switching from Armed to Custom takes longer. Very often when Im opening garage doors, but sometime (maybe depends on the LTE coverage) it will switch few houses ealier. Also when I did switch to Geofencing Mode Im not playing with changing the modes manually at all. My wife second phone is added and all works well with both phones. Good luck.
BTW: why nobody is responding from Arlo, ... I hope they all worked on the software updates, which I believe took place few days ago. I for sure know it fixed my Arlo Door issues with camera not turning on automaticly when I answear door bell call. 🙂
Regards!
Everything was working fine until a few months ago, but now it's not recording/activating in certain circumstances.
Normallly, it's set to geofencing with a schedule for overnight.
During the day when we're at work, geofencing sets it to armed and it successfuly records
On a night, when we're at home, geofencing set it to disarmed except for when there's a schedule.
The schedule is set so that between 11pm and 6am it should be armed. However - it never records (even though I know it should have done). The schedule definitely sets the system to armed, but it just doesn't actually record anything.
If I manually set it to armed overnight, it successfuly records.
Why isn't the armed via schedule working?
Apologies if it's bad form to answer my own question!
Having looked further through the forums this morning and doing some more testing it seems like this is the same problem that others have. i.e. geofencing in "home mode" is not forcing the schedule to go to armed even though both geofencing and schedule modes work independently. Lots of other people seem to have that same problem, and it used to work until some random update last year.
Any update from Arlo/Netgear as to when they're going to fix it?
Hardware H7
Firmware 1.3.314
Samsung Galaxy S8 phone
App ver. 2.7.1_23406
The geofencing function seems to be inconsistent in its operation.
Sometimes it appropriately switches modes and sometimes it doesn't.
So does the app need to be running in order for the geofencing to work??
I have encounted an issue with the system when using Geofencing with a schedule allocated to the home mode, the system currently is not arming based on the schedule leaving the system inactive overnight.
The system was working absolutely fine and following the required settings until I disabled several cameras and set the mode to disarmed due to some requirements at home. Once the settings were reactivated the system has not followed the schedule when in home mode, the geofencing works seems to work correctly.
I have tried rebooting the base unit, disarmed and rearmed the system, reallocated the modes and nothing seems to switch it over, has anyone experienced similar issues and can advise how to correct?
Base Station - FW 1.12.0.1_27940 (Hardware VMB3010r2)
Cameras - FW 1.3.314 (H7)
Hi @Ward_home
Have you tried to set the mode through the web portal then reboot the base station and test again?
