When setting mode that camera 1 detects motion to have camera 2 start recording. Can you get both cameras to record at the same time?
Set up a NEW MODE, after adding the first camera rule, SAVE then go back and EDIT it to add the next camera rule
use
If cam 1 detects, record cam 1
If cam 1 detects, record cam 2
and io take it a step further add
if cam 2 detects record cam 2
if cam 2 detects record cam 1
Make the times of record the same lenght for both cameras
use
Thank you.... It works PERFECT!!!!
