When I try to login I'm getting a message, in an organge stripe, telling me that my session has expired and to please login. When I attempt to login it fails and tells me that "You may be logged into Netgear Arlo in a different browser", and there's no way to continue. I'm not logged in with a different browser or device.
I'm using Microsoft Edge on a Windows 10 laptop. Everything works fine if I use another browser, Firefox or Chrome, but not with Edge.
Any advice will be welcomed.
Thanx,
CFL
Actually, not a good workaround, at least not with all devices.
Doesn't work on my Galaxy Tab 4.
We have already paid for devices so arlo isn't losing anything!
try to clear the cookies and attempt again
TomMac,
Excellent. That did the trick.
Thanks for the speedy (and accurate) reply.
CFL
This seems to have worked, so far
@AP_user wrote:
1> Does system need to be re-registered / synced if physical modem (or IP) is changed? Does system use router MAC address to locate tunnel path to subnet cameras? Reason: may have to swap cable modem and not sure if provider has static IP based on customer account or if IP will change upon changing modem.
No. The base uses DHCP from your router. You should be able to pick the system up from one location and plunk it down in another without changing anything.
2> Latest update to android app regarding security / login changes is severely flawed. What wasn't broke now is. Instead of keeping message on to log out, have message displayed, time out then force logout back to login screen as most users can't get rid of message long enough to get to manually log off the system.
Right now, the workaround is to open the app, get the error message, tap the multitask (asingle or double overlapping rectangles next to the home button) and click on the "X" for Arlo. Then open the app normally. This will have to be repeated any time the error is displayed.
3> As an admin, I'd like to turn off the SSID beacon on the router.
Not currently possible since we have no access to the base.
Check all the other threads here for the same issue and workarounds.
It's not a fix since you'll have to do this every time you get the error but use the multitask button (one or two overlapping rectangles) next to your Home button. Click on the "X" for Arlo andrestart the app normally.
For whoever from Arlo who reads this...I have the same "session expired" issue as the others. My irritation is that if I get a push notification in the middle of the night I don't want to have to log in again. I want to access the camera as quickly as possible. It'a a basic safety issue which is why I have the system. If this can't be changed back to the way it was before the early March update then the value of the Arlo system is very much diminished.
Please change back to the "old" way as soon as possible.
I am beginning to suspect that this software bug is NOT going to be solved/cured.
There has been no official comment by Netgear / Arlo, in spite of the many many complaints on this forum and on the Playstore reviews.
The reason could well be the release of completely new software for the Arlo cameras, as we saw demonstrated at CES in January.
A reply in January from the Arlo offices to my enquiry on this new Arlo Smart was:-
‘Arlo Smart are added account security features that are available for all Arlo cameras on an upgraded Arlo Smart account plan. More details to come so please stay tuned.’
If you watch the YouTube video about Arlo Smart you will notice changes in the Arlo app, such as the ability to call 911 as a working tab direct from the app.
This change to the app was advertised as ‘ Available Spring 2018 ‘.
I suspect therefore no more ‘upgrades’ to the existing app, but the roll out of a redesigned app ‘shortly’..
YouTube video :- https://youtu.be/SNiXXSphTQs
Meanwhile we can only use the workaround as kindly supplied by jguerdat.
Engineering is aware of this issue and hopes to have a fix available very soon. We apologize for any inconvenience caused, I will provide an update as soon as I have more information on the fix.
Thanks for coming back to us on this, it has caused much frustration.
All I can say is lets have a fix on this software bug as soon as possible..........
Previously Arlo was very reliable and that is why we purchased, we need to get back to 100% reliable..
Ever since the new update the Arlo app has been EXTREMELY annoying!! I am going to stop recommending the Arlo system immediately. Please fix this annoying issue. Everytime I want to look at my app I have to login. Hate having that stupid orange bar getting in the way to log out and then log in. Get rid of the orange bar telling me that my session has expired. Move it to the bottom of the screen so it's not in the way. And set the timer on it for a longer period of time so u can actually log out before the yellow bar reappears. If you can't fix, I can send my 14 year old to fix it for you!!!!!
Hi James C,
Thanks for looking into this issue, I am having the exact same issue on an S7 android 7.0 with the most recent Arlo version.
Do you have an estimated time to resolution through an app update, as this issue makes our home security system unusable? This is unacceptable for a security camera system company to not have thoroughly tested versions prior to updates.
In the meantime, is it possible to roll back the last app update to the prior version that was working?
Press the overview button and press the box that appears with "close all" in it then click on the arlo app and it should open without logging out and back in.
Have you tried just closing the Arlo app instead of all? That's what I've been doing successfully.
My Arlo (Android) APP ver is 2.4.7_19361 dated Feb/06 2018;
I have this isse too for just about a week, so I thnik that is not due to APP version, but something done at their server site...
I've had the same issue for the past week or so on my Pixel 2 XL. I ended up doing an uninstall > reinstall with the android app, and it works again. No more timeout messages when I open the app via fingerprint.
I am having the same issues with the phone app keeps expiring. It is very, very frustrating. I was going to have this system installed for my parents due to them being elderly. I had just talked them into get this security system. I am very disappointed because this will only upset them if they had to continously log in to see the cameras. I will be looking for another security system for them. I will not be promoting this security system to any of my friends, or family members as long as I am having this issue.
