Installed a second arlo camera and although I get live pictures when I go to change the mode the camera does not appear a a devise so the mode cannot be changed. Any ideas? Thanks
Thanks a lot. Problem solved. My cameras are wireless. So only the base is listed. I added a mode so now my system is set up
Not sure what yours describing but it sounds like you need to add a rule to each mode for the new camera. Edit each mode, add a new rule and use the pull-down menus for which camera detects motion as well as which one records, selecting the new camera for each step.
Thank you.. What I mean is, that when I press the mode button only one camera appears on the devices, so I cannot change the mode for the second camera because it is not displayed.
This rather sounds like you're describing a Q camera. What system are you using?
If using Q cameras, each one is displayed separately when selecting the Mode tab. For the wireless cameras, the base is displayed. Selecting the base or a particular Q camera takes you to the modes. Perhaps that's what yours missing?
