Scheduling seems Buggy
Hello,
I just tried to setup a simple time schedule for my Arlo Pro 2 system.
Timing „armed“ should be from 11PM to 6AM. I try to setup the schedule with an Ipad.
Here the description of the flaws:
1. I can setup the desired time however when I get out of the setting mode it jumps back to 12AM start time. So it seems the SW cannot handle to go over midnight.
2. I am setting up the schedule for all the weekdays, however it leaves out Mondays.
3. I try a workaround and define the schedule to 11PM to 11:59PM and 12AM to 6AM. However with the same behaviour that the SW is leaving out Mondays.
4. When I compare the schedule between Ipad and Iphone they appear as not synchronized.
Anyone else having these issues with scheduling? Any solutions?
Best regards!
I find use of a browser for modes, rules and schedules works best currently.
Also, you're right, the schedule doesn't allow passing through midnight. Schedule till 11:59PM and also another starting at 12:00 AM.
