Scheduler
  • 3922 Views
DavidCockayne
I'm trying to set up the the scheduler but not getting anywhere. The instructions say "Drag and drop the buttons", but I only have one button "All motion on" so everything is on!
This was bought in the UK November 2015.
DavidCockayne,
You can add a new mode and time frame for that mode by tapping on the green + icon in the top right hand corner of the screen. You can also edit an existing mode within the schedule by tapping the time frame for that mode and changing the times. I hope this helps!
DavidCockayne
Thanks JamesC,
I have tried what you have suggested and got as far as setting the start and end times for a single day, then clicked "add". Unfortunately this does not update the schedule. Still stuck with "al motion on"
DavidCockayne
Problem solved. I used the excellent Netgear live web chat and was guided to a solution within minutes!
