Schedule two different modes without overriding
I see this has been asked many times before but I can't seem to get my head around this.
Followed the fourth post (sorry can't seem to link the post) from here https://community.netgear.com/t5/Arlo/Changing-record-times-in-a-schedule-mode/td-p/1043215
I had two cameras for which I had a mode to schedule recording when detecting motion And had a schedule which would set this mode into action from 2200 to 0600. Now I have a third cam, say main door cam, which I want to record video on motion 24 hours. So create a new mode for the same. Added it to schedule to the existing 'Night mode'. Looks like the night mode overrides the schedule for the 'main door cam mode'.
How do I get two cameras to be scheduled to be active from 2200 to 0600 and one camera from 0000 thru 2359 ?
This image is what my current schedule looks like : (Night mode is obviously overrirding the main door Mode ) http://imgur.com/a/cMHVk
To get around this, for now, I have added my main door cam to the night schedule mode - but I don't understand why I cannot use two different modes in a schedule even if they are overriding.
Two other questions
1) If I have cam 1 detect motion, how do I make cam2 start recording as well ?
2) Is there some sort of locking available on cameras ? Can I lock a camera to a base station ? So in case it is stolen, the thief can never use it. Also say if a camera I owned is stolen, can I ever track if the same camera comes online again ?
You will need two modes - Mode 1 with all three cameras and Mode 2 with one. Then schedule Mode 1 from 12:00AM to 6:00AM and again from 10:00PM to 11:59PM. Then schedule Mode 2 from 6:01AM to 9:59PM.
How do I get two cameras to be scheduled to be active from 2200 to 0600 (call A-B ) and one camera (call C) from 0000 thru 2359 ?
It's ALL in the modes...
You have cameras A,B,C.... what you have to do is split them up for best control
You could make the modes for A -B- C-AB-AC-BC for all the possiblities, defealt armed is ALL ON
create indiviual custom modes ( add a mode ) for cams , esp for C ( follow method found in the FAQs )
For the time 2200-0600 just use the default mode ARMED ( all three will be armed )
(BTW** schedule does not go thru midnight so go 2200-2359 and nexr day use midnight to 0600 on next day )
For the remaining time 0601 to 2159 use the mode just for camera C ( this way it is on 24 hrs per day aremed )
Two other questions
1) yes ... make a mode with rules where A senses A records AND A senses, B records ( both will be activated )
2) No and No and No... just place it out of reach and or use a teather to the screw hole on the cameras to help prevent someone knocking down and taking
Oops - I did forget to answer the second part... Thanks, Tom.
No problem... I'm here to help 🙂
this may also help;
