Is there a way to have a different schedule per camera? Not very convenient to have the same schedule for all cameras.
If your asking for more than one schedule plan, to my knowledge, no.
But with 4 basic rules there shouldn't be a problem with 2 ( or more ) cameras.
You start with the ON ALL and OFF ALL rules, then add ON rules for the indiviual cameras... When the rules are applied to the shedule, its easy to make any combo of the rules. It may look difficult at first but after a few times use, it works well.
PS don't forget to SAVE after making schedule.
