Schedule Mode
One of my cameras does not record when on schedule mode anymore. It works fine in 'alarm on' mode.
(I have already opened/closed batteries and reset the base station just to get it to work after update).
5 REPLIES 5
If it works in your Alarm On custom mode, it should work in Schedule mode as long as the schedule sets Alarm On mode to be the active mode for the time of the day you set. There may be an issue with your schedule settings
Verify the name of your mode. If you created it, no problem. However, some folks have had remnants of old firmware remain with All Motion On/Off modes still available which are known to have issues with the latest firmware. You definitely don't want to use them.
Hi. I have exactly the same issue. Until 1 month ago schedule was working well but after an update the motion sensors only work on armed mode. Strange. Any ideas ? Thanks
Lots of ideas but we need to know more about what you've tried. Be specific. Power cycle the base for starters.
Problem solved. Issue was that the time zone (option in settings) was not correct, so schedule mode was calibrated to a different time zone.
