Same. Original Arlo camera keeps returning to this state after I replace batteries daily. Think it's mostly the reset of the battery door but it chews through the batteries likely because it won't connect. Other 3 identical cameras and all my pro 2's operating without issue. Suggestions?
Swap cameras around to see if the problem stays with the camera or the location. Then you'll know what needs fixing.
I tried several locations and each time I experienced the same problem by the next day and depleted batteries by half on average. Continues to be consistent in not working like the rest of the cameras.
I have removed and added each time I moved the camera.
I am open to suggestions
I assume you mean that the same camera had the same problem? If so, open a case with support here. If it's a faulty camera, that's the only way to get it replaced.
