Routine to change modes quickly
  • 1 Reply
  • 1883 Views
johnnydangster
Currently I am using Geofencing as the mode for my 4 Arlo Qs.  If I'm home, then records but do not notify.  If i'm not home, record and notify.  I had to create modes for each device which is a pain.  However, if I have contractors or guests over and I'm not home, I'd have to go into each of the cameras and change the mode individually..
Could you please implement like a Mass settings to say apply Mode 1 which sets all of the cameras to a certain settings? For example:
Alerts only outside:  Outdoor cameras record and alert, indoor record but no alerts
Recording off: Everything off
Lisey
Have you tried to create your own new mode with those controls and select that when necessary?
I know its not very user friendly with the zones and modes -
i set up my own mode to use for geo fencing called externals only so when i, home it switches to that
might require some fiddling with the modes but it sounds likeit coudl be done?
