I have Arlo pro cameras.
I had one set to not record motion.
Now I want it to record motion.
Use used to click the pencil to change the mode. Since they updated the app you can no longer do that. The pencil is gone.
I’ve clicked ever icon for the camera I want to enable motion recording and I can’t figure it out.
Please help. Does anyone know?
Select
- routines
- mode
- arm away
Then look for a rule for your camera
If there is a rule, the select the > to the right of the rule.
If there is no rule, press "add device rules" at the bottom.
After you get this working for Arm Away, do the same for Arm Home.
Select
- routines
- mode
- arm away
