Replace Base Station With A New Base Station
  • 2 Replies
  • 9152 Views
  • 2 Likes
hogieaz01
How do I get step bt step instructions on how to replace my old 1st gen base station to the 2nd gen base station.
Streak2
Master Master
Connect your new base station to your network, wait for the 2 green lights. Use the app to add a new device, select your new base station.
Then one by one remove each camera from the old base and sync it with the new base just as you did when you did the initial installation.
hogieaz01
Thank you.  I was afraid of that.
