Removed camera won't resync. Restarted Base Station. Can see camera from Alexa.
  • 1 Reply
  • 3018 Views
  • 1 In Conversation
zarko
Couple of days ago both cameras went offline. Then I restarded the base station, at first nothing happened and then I removed one of the cameras from the application. The other one in the mean time started working normally. But now I can't resync the removed camera. I can see the camera from Alexa, even active it and I see that it can detect motion but nothing is recorded on the cloud. When I try to sync it flashes slow blue and then fast blue as if it is connected to the hub, but I don't see it in the application.
zarko
I made the factory reset of the hub and now it all works fine. I thought there would be more effort to set all back but it went very smoothly. It remembered the names of the cameras etc.
zarko
