Refurbished arlo camera - Says checking for update
Hi there,
I have bought a refurbished arlo camera and struggling to set up on the arlo app. On a selet on the add new device and click on select base station. It is coming to the screen saying (Checking for updates... Give us a couple minutes to search for any available firmware updates.) and it stuck there.
Could anyone give me some advice please.
The old way of syncing cameras fortunately still works. Briefly press on the Sync button on the Base followed by briefly pressing the Sync button on the camera. The blue camea LED should blink slowly for a couple of seconds then start blinking rapidly indicating that the camera has synced. If that does not happen, then the camera may be defective.
Brian
Thank for you comments. I did follow the instruction, everything like working fine. But on the app I try to add the base station into the app, but always stuck on the screen saying checking for updates available firmware for two hours. I have no idea how to solve the problem.
Srieng
Have you tried to remove power from the base then powering it back up? That usually works for me.
Brian
Thanks for your reply. I did a few times, but it come back the same. And I also try to reset the base, now the camera light on the base is orange. Any idea?
Srieng
I'm having the same problem
Checking for firmware update failed
(server is taking too long to respond. please try again.),
I purchased today new from Costco 9/30/19
Was wondering if you filed ticket with support or if you were able to find a fix?
I'm ready to return tomorrow... if I can't connect the base with out issues.
currently I have 4 Lorex POE cameras connected on the same Xfinity Router.
I was told shouldn't have an problem adding the Arlo Pro 2 HD Cameras...
Thanks for any feed back / solutions.
you didn't mention if it is the base or the cameras that are giving this message, or both. If it is the base, you might try to unplug the power for a few seconds and power it back up again. Also, you might check with your ISP to be sure that the router does not have anti-virus software built into it that is blocking the communications from the base to the internet. Also, you might want to be sure that ports 80, 123, and 443 are open on the router.
If it is the cameras that are giving this message, try removing the battery and re-inserting it.
As a final test, you can push and hold in the button inside the tiny pin hole in the base until the LEDs on the base all start flashing amber, to do a factory reset.
Brian
I tried the fixes to no avail. It was the base having connection
