Record while live
The system should record as set in the armed rules even when streaming live.
Live Streaming has always Over-rode the set commands as your in physical control...it was designed this way because the cameras time out at the 30min mark even in live streaming ( to save batteries ) AND if live streaming you can always manually start a record session
So you have to think to push the recordbutton when you look live. But another question why do the most records stop after 10 seconds ( or less) even when there is more movement en noise ? ( i only have one time 5 minutes) . The rest is 10 seconds or less.
under modes you can adjust the recording length of an automatic recording up to 120 sec, FAQs tell how to do this as well as numerous posts.
thxs, overlooked this option.
