Record on some cameras only while system is not set. To record people coming to the door.
I have 5 cameras. 3 inside. 2 outside. I want my 2 outside cameras to record at all times but not send notifications. I want my 3 inside cameras to record and send notifications only when I have "set" the system to armed. What I am trying to do is record when parcels are dropped off, when I am home or not, and not be notified. Is this possible?
You need a CUSTOM mode for the two outside cameras. ( add a mode under MODES )
Add the first camera outside, and save, then go back and edit the new mode to add the second camera.( add alerts as wanted )
Call the custom mode something like OUTSIDE or Front door.
So when you want you can use the outside cameras with the custom mode and the armed mode for all cameras.
tips;
Only ONE mode can be used at a time
any camera NOT in the active mode is OFF
To add additional cameras to custom mode, add the first then save, go back and edit for more.
