Rechargeable batteries vms3230
  • 1 Reply
  • 1464 Views
OliverBok
Im tired of spending alot of money on batteries...
Where can i get rechargeable CR123 batteries that will work with my Arlo VMS3230 cameras?
I live in Sweden.
While the Tenergy rechargeables are the ones Arlo has certified, other brands that are rated in the 600-750mAH should work. The usual issue is that the physical sizes may vary enough to make it difficult to install and/or remove the batteries. Run away quickly from any battery that claims more than the above rating since they're lying through their teeth.
