Re: All cameras go off line
First, check your base station firmware to see if it is 1.12.2.1_2798, if it is, then it could be the firmware issue that we all having. This firmware is creating a lot of issues, most issue is pixelation, blurry and herky-jerky motion.
But you can still try to do factory reset, but you will lost all the connection, you need to re-sync all the camera. Good luck.
Try swapping cameras around to ensure it's not something about the location that's causing the issue.
I'm confused.
Okay. your firmware is 1.12.2.1_2798.
Are you saying some camera working fine, some camera is not working?
What base station do you have? is it basic, pro or pro 2?
how camera's? how many is working, how many is not working?
You are the luck one, this horrible firmware does not affecting you.
I would move the problem camera to the base within three feet,
delete the problem camera from the base, then re-sync again,
if not working, then you can do factory reset (lot of work),
if that doesn't work either, I recommend you to connect Arlo support (Chat support) for replacement.
Can I ask you few questions?
1) when did you purchase problem camera?
2) The 3 camera's that's working, were you view them thru IOS or desktop computer? or other equipment?
3) This 3 camera's, were they set up in "Best video" option, how long is the video (120 seconds)?
4) Is it possible you can share one of your video that is after the firmware upgrade
( time of recording is more than 40 seconds)?
Your help is appreciated.
I am having the same issue as well. I have 4 Arlos and 1 Arlo Pro. the Arlo video quality is terrible and pixalated, grainy and skipping whether on the app or on the website portal.
One camera is constantly going offline. I moved it within a few feet of my base station and it still drops. I have been trying to chat with tech support but they have not been very helpful yet. Asking me to do basic troubleshooting stuff like reboot my router. The Arlo Pro quality is perfect and working as before.
I turned off my wifi. Fresh batteries, power cycled everything across network, relocated base, moved cameras. My network is gigabit up and down. its not my network. Again the Arlo Pro is fine.
After trying everything I went and deleted every camera, reset the base and all cameras and started from scratch. No help. I am with the prior posts. This is a firmware/encoding/compression issue. I am also on 1.12.2.1_2798.
In case tech support is out the my case is 40898666.
2) I have only viewed on iOS
3) video settings are at Optimized and we’re set up that way but I only get 10 seconds of recording
- cleared out library but will go out shortly to trigger camera then upload video *there HAS been a firmware update since I set them
Up
Yes, this current firmware 1.12.2.1_2798 is acting very weird, some people having issue with basic, pro or pro 2. your system only affected on arlo wireless basic.
My recommendation to you, review this two idea's, if you want to support it,
please leave a like, so this issues can be resolved ASAP.
Roll back to previous firmware 1.12.0.1_27940 from current firmware 1.12.2.1_2798:
Manual Firmware Update:
https://community.arlo.com/t5/Arlo-Idea-Exchange/Manual-Firmware-Update/idi-p/1701867
I agree. The cameras do look acceptable and then the buffer runs out or something and it all goes blurry. It takes about 10 seconds to fully convert to mud.
carwer , That's why your three camera's are fine, because you only have 10 seconds, most blurry /pixeled video and herky-jerky motion does not start until 15 or 16 seconds later.
SInce your purchased is over one year, your warranty is over.
But I recommend you to check your camera firmware version and compare with other three cameras that works.
The camera firmware should be 1.3.314, if not, try to update to that version to see that would helps.
What color was the Internet LED on the base? Amber means no connection to the servers.
Could be. Try rebooting the router and base, in that order.
It's possible. You'll need to open a case with support to get a replacement:
1  -
1  -
1  -
