Problem with times on schedule
Schedule will have to be set from start time to midnight, then midnight to stop time.
correct...you CAN'T go thru midnight. So break the schedule into 2 parts. Up to midnight and second half on the next day after midnight
True, and I'm pretty sure it will force you to start the second block of time at 12:01 (after ending the first one at 12:00). Something else I've noticed is that the start time will change itself after you set the stop time, so after you put in your start time and then your stop time, go back and recheck the start time just to be safe. It can be pretty annoying, but you'll get there. I also had better luck by starting at the first of the week, whatever day is at the far left of the schedule, and then working my way through the week from there.
