sometimes remotely rebooting the base station will bring your cams back. But sometimes using the soft reboot will hang the base station so you'd lose any cams that were still working.
I put an IP switch between my base station and power bar, giving me the ability to do a hard base station reboot in case the above happens.
Not guaranteed to get your cams back, but will for some situations
here's just one example
but many brands can be found at best buy, amazon etc
This is the model I got, works great using my cell phone to turn off/on
https://www.amazon.ca/gp/product/B01LNPUGZ4/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
BTW, sometimes the "offline" is a display issue that can be quickly resolved by logging out and back in or by using a browser instead of the app or vice versa.
