Printing Video with Dates for Court Case
  • 4 Replies
  • 3612 Views
PeaSoup
This my first time posting, and I have had this camera system for 3 weeks, so I'm still learning.  My lawyer needs paper copies of frames from videos to hand to the judge for a court case.  There, of course, needs to be dates.  When I use IE to go to my Arlo library, and I click to run an individual video, it's like the video pops up in an overlaying window, with a white date-and-time banner above it.  I've been fiddling around to see if I can print just that window, but have had no success.  Any ideas?  Thank you so much!
Since your in IE, then it's prob windows based...
Two options;
1) use the program the comes with windows called SNipping Tool , allow a capture and then email or paste into paint prgm to print.
2) Alt - Print Screen buttons on keyboard is the old try-true method
Two options;
PeaSoup
Thank you very much, the snipping tool will work!  Will it work automatically to print the window in something other than IE (without snipping)?  I have many to print out, thanks to my stupid, creepy stalker neighbor.
Not sure if I understand what your asking...
But the snipping tool allows you to SEND snip to an EMAIL OR, SAVE as a file.... it doesn't print by itself, but once captured, you can also RIGHT-CLICK the mouse to copy the snip and paste into any progm like word or paint and print from there.
PeaSoup
Snipping is great, and I am so relieved that you mentioned a way I can do this.  But, I'll probably be dealing with 50-100 pics, and snipping requires a few steps for each video.  I was hoping there would be a way to right-click and print each video frame (with the date) without snipping (to reduce the steps).  Maybe there isn't an easier way, and that's okay.
