Port forwarding not working VMB4540
  • 1 Reply
  • 945 Views
WingKit
Hello, I have been using the port forwarding function for a while but now it doesn't work after some updates.
I have set my DHCP & NAT as manual and set the port for forwarding but the app is showing the port forwarding is not working. I have also tried to disable some security/firewall settings in the router app.
I am using iPhone and my router is eero.
Make sure that the port is open using a PC web browser ( https://canyouseeme.org/ )
Also make sure that the smarthub's local IP address hasn't changed (and matches the forwarding rule).
