Poor picture quality on 1 of 3 cameras
I just installed 3 cameras and two of the cameras are very clear. However, one of the cameras does not have a clear photo quality at all. I have tried moving it to another location but it is still not clear. Do I have a bad camera that needs to be replaced or is there something I can do to correct?
Are all three cameras on the same Video Quality setting? The poor one doesn't still have the plastic film over the lens?
Dbugs,
Adding to steve_t's suggestion above, what is the signal strength for this camera? If you move the camera close to the base station (within a few feet) do you experience the same behavior?
Yes, all three are set to the same video quality and the film has been removed.
Same picture quality at any distance
May be a faulty camera. Open a case with support.
