Library thumbnail
Image quality when played
Hi. Does anyone know why this happens? My cameras only recently went bonkers. About half of all library records play with the image partially or completely covered with green screen, and appearing as smeared thumbnails. The problem affects both of my cameras pointed towards my entryway so I’m inclined to think it’s a network/software problem. Solutions welcome 🙂
Not the internet connection its the wifi connection speed which im guessing given i can connect under the camera at these speeds and the base station is in the server rack with the wifi module then the camera should also have a strong signal - i too am between full and 2/3.
i have 5 cameras and only 1 is doing this and this is only since upgraded and reconnected.
@gaw370 wrote:
I know its not the wifi range / coverage as i get 140Mb/s to the area where the camera is
That's not directly relevant, since the camera isn't using your home wifi.
One practical thing you could try is swapping two cameras, and see if the problem moves with the camera or stays with the location.
I stand corrected ..
I have three camera equal distance from base station all
Showing a min of 2/3 and only one Has been having this issue since the last update
That’s odd. I too, have seen this just today. First time since I bought the stuff last July. Add something else to the Arlo complaint list.
Hello community,
@ThinkDifferent Thank you for the SS
May I ask if it's possible to provide a screenshot of this green/pixelated image you all are experiencing?
Thank you!
For some reason I can only attach 1 image so I attached a screenshot of the library thumbnails to illustrate the problem. I would have also wanted to include captures of the playback, where the screen goes green or black depending on how much of the thumbnail is distorted. Fully distorted thumbnail = black screen playback. Partially distorted thumbnail = green screen playback where the image is dIstorted in the thumbnail.
Correction: Your system won’t allow me to attach any images in response to your request. Please see the images at the start of this discussion as those are mine and the problem remains the same.
Thank you for the update. I have the images from your first post. I sent you a PM as well.
Photos attached
Anyone have any more suggestions??
The problem is now less persistent at one of my properties but remains persistent at another. So right now I’m having the cable company look at their network router to see if that is contributing to the data loss, because the cameras function similarly when switched—glitchy at one property, not so at the other.
One of my cameras is doing this often now. It never happened before, no problem for the year that I’ve had them. Now it’s done this three times in the past couple of weeks.
Any Arlo people out there know what is causing this? We would love some input.
Hi StephenB
You suggest it may be a bug. Any idea if it’s being addressed?
Yes, I thought so. No comment
